Re: My M front rims mounted inside of hubs. WT*!!!
Posted by mkirsch on August 14, 2012 at 05:48:11 from (64.80.110.75):
In Reply to: My "M" front rims mounted inside of hubs. WT*!!! posted by Patrick HMD on August 13, 2012 at 17:02:05:
Good grief people, it's not difficult at all!
Jack up the tractor.
Remove the three bolts.
Swing the bottom of the tire inwards slightly.
Lift straight up.
Swing the top of the tire out and over the hub.
Lower the tire straight down.
Pull the tire out from under the hub.
EASY!!!
