Posted by FBH44 on August 14, 2012 at 05:50:15 from (64.85.215.55):
In Reply to: F-30 pics posted by BT in NE on August 13, 2012 at 13:43:13:
Could I respectfully disagree a little bit? I agree, the farm clothes are the best, except for the sheet metal. Once iron / steel corrosion starts it doesn"t stop, the metal continues to attract and collect moisture and the corrosion proceeds right on down, unless you stop it. Doesn;t mean much for heavy cast iron housings or channels, but the sheet metal will rot away. I always think it is best to at least remove the rust and prime the sheet metal with a primer. Use different brands of primer if you want to keep an old look, but at least stop the corrosion on the thin stuff. And keep the old beauty indoors.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
