Re: help with valves
Posted by mkirsch on August 14, 2012 at 11:59:07 from (64.80.110.74):
In Reply to: help with valves posted by Jimmy in TN. on August 14, 2012 at 10:54:38:
Just for perspective, the difference between 14 and 17 thousandths is .003 inches.
It's a very very small amount, and really not worth hedging over. You could set them anywhere between .014 and .017, and the tractor will run fine.
Just for giggles you could set on at .014, the next at .015, the next at .016, and the next at .017, then start over... It'll still run fine.
Of course normally you set the tightest measurement (.014) and set them all the same.
The range is really for performing tune-up checks. If it's between .014 and .017 you don't need to adjust.
