Re: Lining up the engine to the bell housing
Posted by D Slater on August 14, 2012 at 14:15:33 from (184.15.20.202):
In Reply to: Lining up the engine to the bell housing posted by BigTone on August 14, 2012 at 13:30:11:
If you lined the clutch plate up on the flywheel. Extra clutch shaft from a salvage tractor works good. Put the transmission in neutral the PTO in gear and turn the PTO shaft when the engine gets to the splines.
Dowel pin on each side of the bell housing helps keep the engine straight. Some clutch housings have a casting lip on the inside bottom part that the ring gear will catch on with dowels used though. If a problem I grind the housing enough to clear.
