Re: Lining up the engine to the bell housing
Posted by bobia on August 14, 2012 at 17:22:42 from (64.12.116.73):
In Reply to: Lining up the engine to the bell housing posted by BigTone on August 14, 2012 at 13:30:11:
On a 706 I made a line up shaft put clutch on and tigthen up pulled it as clutch was centered then moved engine as we had motor on stands with wheels got spline started and then used all thread to help line motor and rearend and brought it together. on 656 clutch and shaft were smaller sowe used a long socket with duct tape to make it tighter went to gether like other one. this was on a tryclce tractor so we were worried about rolling around took some angle iron and bolted to front end. job donewithout any hurts
