Your far left lever should run the left side, and the right side is ran off the center lever. the lever on the far right is the hydra-touch for the two point and that lever stay where it is left at. Get you fuild changed then check you pressure with a wet gauge. 1500psi should be about what you want. If not there is a square box on the pump. This is where you can adjust the pressure. Take off the cap and shim the spring a little at a time to add pressure. A skinny washer the same size as the spring works good. Also right behind the gear shifter are a coulpe valves you can turn that has to do with how you pressure is applied. Make sure the valve is in the right spot for what you are tring to do. Hope this helps
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
