Re: Farmall utility 240 work with a rototiller?
Posted by Rex Simpkins on August 15, 2012 at 04:20:35 from (98.192.242.212):
In Reply to: Farmall utility 240 work with a rototiller? posted by Nathan2 on August 14, 2012 at 19:53:22:
I have a 240 Utility with a 4 foot king cutter tiller, it is off set to the right to cover the right wheel track. 1st gear works perfect. In new ground I plowed and disked first then it is a piece of cake with the tiller from then on. Do not let anyone tell you it too fast. At pto speed in first gear mine is a little over 1 mph. I would not trade this set up for anything
