Re: Farmall utility 240 work with a rototiller?
Posted by K-Mo on August 15, 2012 at 04:36:37 from (67.55.164.5):
In Reply to: Farmall utility 240 work with a rototiller? posted by Nathan2 on August 14, 2012 at 19:53:22:
Think of it in terms of how many times a tiller blade hits the ground in distance traveled. Depending on soil conditions, the 240 could be a little fast. If you have a concern about ground speed, I would suggest a six blade tiller rather than a four blade.
