Re: Farmall 400 or 450
Posted by mkirsch on August 15, 2012 at 05:20:50 from (64.80.110.74):
In Reply to: Farmall 400 or 450 posted by DC_PA on August 14, 2012 at 21:32:23:
Whatever the serial plate says it is, it is.
Lacking a serial plate, you will find that a 450 almost always has C (1957) and D (1958) date codes in the castings.
There will be holes in the top of the cowling over the hydraulic valves so that you can switch them from one-way to two-way easily.
Odds are, if the hood emblems say "400" it's just a 400 with a replacement engine. Of course, anything could've happened in the last 55 years.
