Re: Clutch stuck on SH
Posted by mkirsch on August 15, 2012 at 05:28:59 from (64.80.110.74):
In Reply to: Clutch stuck on SH posted by Va Gasman on August 14, 2012 at 18:02:35:
I see you have a Stage II.
Remove the access plate on the bottom of the torque tube, and you can get at the entire clutch and pressure plate with the brake cleaner.
Worse case you can replace the clutch and pressure plate through the access hole without splitting the tractor.
