Posted by The tractor vet on August 15, 2012 at 07:44:23 from (76.212.225.255):
In Reply to: smd-ta hyd. posted by william nickles on August 14, 2012 at 17:59:40:
Have you plugged a gauge into the remotes to see what pressure you have there Ya only need three gallon a min. for steering . What implements are you trying to raise and what size cylinders are you using . Your working with a low pressure system and a tractor that is old . Plus the fact that that SM/TA diesel has more then likely had extensive field testing thru it's life and your problems may be due to a plum slap wore out pump .
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
