Re: labor for T/A in a 1486
Posted by Owen Aaland on August 15, 2012 at 11:16:17 from (216.47.35.76):
In Reply to: labor for T/A in a 1486 posted by jamienky on August 15, 2012 at 08:16:10:
IH flat rate is 20 hours for TA, MCV overhaul, clutch replacement, and one hour cleaning. But you're dreaming if you think that you can do it in that amount of time on a 30 plus year old tractor.
IH flat rate is 17.2 hours for replacing TA assembly. At the time the rates were established there was no such thing as shimming the TA assembly for proper end play. You could add another .5 for that.
Add to that cleaning the tractor before working on it. Add 1.7 hours for replacing the rear engine crankshaft seal or .8 for R&R flywheel for resurfacing and clutch replacement with tractor already split.
Add 1.0 for overhauling the MCV. Flat rate for MCV overhaul is 3.3 but since it will already be off, subtract 2.3 flat rate for MCV pump replacement.
Add to that any time required for any additional repairs or problems you run into.
