Posted by CNKS on August 15, 2012 at 15:00:22 from (216.144.104.128):
In Reply to: rear seals posted by dino in iowa on August 15, 2012 at 11:30:45:
Remove the rear wheels and the caps on the axles, the seal is in the cap. When I remove wheels I remove the rims and the wheel weights to lessen the weight and use an engine hoist, or whatever it's called.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
