Re: torque specs on oil pan
Posted by sflem849 on August 15, 2012 at 19:30:11 from (166.181.3.135):
In Reply to: torque specs on oil pan posted by rustred on August 15, 2012 at 18:27:01:
Yes you were. 15 is probably the oiled torque spec. There is no way you could wreck a gasket at 15 ft lbs. Not to mention the fact that the rim of the pan has the strips of metal to help spread out the force of the bolt. No way in heck you can evenly torque to 15 ft lbs by hand.
