Re: Coil will not fire
Posted by Fritz Maurer on August 15, 2012 at 19:45:14 from (216.137.136.147):
In Reply to: Coil will not fire posted by FrankxR on August 15, 2012 at 19:05:18:
Put the coil on the tractor and test it under the conditions it will actually operate. Wire it up, turn the switch on, and open the points with a small brass rod (just kidding) and a spark should occur when the points are opened. When the points are closed, you should note a small discharge on the ammeter. If no discharge, the points are dirty or the primary circuit is open.
