Farmall SMD Doesn't Run Smooth At Idle
Posted by FarmallDaniel on August 15, 2012 at 21:29:16 from (68.117.50.178):
I have purchased a smd farmall that doesn"t run smooth at idle however if you work it at all with a load it runs fine it has a rebuilt head on it kind of smokes some blue at idle do I have injector issues or timing of pump or ??? anything to try be great
