Re: Coil will not fire
Posted by Janicholson on August 16, 2012 at 05:44:02 from (199.17.6.86):
In Reply to: Coil will not fire posted by FrankxR on August 15, 2012 at 19:05:18:
For a good spark, it needs the condenser in place. There are interactions between the condenser and the secondary that are important. When testing as you are, the wire tor the distributor must be disconnected. There needs to be a condenser from your grounding jumper, and ground as there is in the distributor. The coil case in not connected to the windings.
I bet your points need to be cleaned and the pass through connection checked for a contact to ground short.
Jim
