Look close at the lever that the t/a handle moves when shifted on the side of clutch housing. See if a part # can be read. If its 359507R1 thats a 400 chassis. If its 366352R1 its a 450 chassis. The serial number you posted could be for a 400 or 450. I just mentioned the serial number break in case IH stuck the 450 lever in some of the last few 400 tractors. They would have a over 40,000 serial # though. way above what the 450 tractors went to. 400 tractors also have a clutch pedal travel stop bolt in the very bottom of the pedal. It has a square head with a jam nut. 450 tractors didn't use the bolt. Lots of other things to look for but none are fool proof after the years since made. 450 used a all plastic covered steering wheel that went on a splined shaft. 400 was keyed and just covered on the outer ring. 450 used a key switch below the instrument panel. 400 in the panel. To ID the engine look for a serial number on a raised flat place in the block casting just above the sheet metal cover on the oil filter side of the block. If no number can be found it may be a replacement block. If is has a serial it may tell what tractor it started in. Guess you found C-281 on the block. Look forwar on the block from it to find a date code. Raised cast numbers and letter. Like 4-8-C. Thats the month and day casting was made with the letter representing a year. Depending on numbers and letter you have can tell when the block was made.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
