Re: F20 wide front serial designation
Posted by oldiron29 on August 16, 2012 at 14:14:32 from (74.88.11.200):
In Reply to: Re: F20 wide front serial designation posted by ET on August 16, 2012 at 07:31:06:
ET, I do have a 38" F-14 wide front that was original steel wheel all around. I do not rember
if it has a W after the serial #. It is not close by so I can not check it right now.
I do think only the late F-20 had wide fronts and the W after the serial #. If it is per 38"
The wide front was probly added to a tricycle tractor. oldiron29
