Re: Towing Farmall H
Posted by Heat Houser on August 16, 2012 at 17:50:30 from (69.66.35.73):
In Reply to: Towing Farmall H posted by youngfarmer on August 16, 2012 at 10:33:27:
When ever you tow a tractor with the rear wheels on the ground, it is a good idea to have the engine idling while you tow. On your H, the top shaft is the only one spinning and it does not dip into the oil so no splash lubrication to the tranny. By running the engine, you have the bottom shaft spinning and oil splashing around.
Pulled my 560 20 some miles that way.....but not at 25 mph. Maybe 15-20 mph at best.
