tjiniowa said: (quoted from post at 13:27:14 08/17/12) Service manager at CIH that I know told me to pull the TA housing out with the engine, would be easier, could then use hoist to remove it from engine, don't that sound easier, or not. He also said it books at 20hr job.
How you split it depends on the equipment available.
We always split the speed transmission out with the engine. If you have a stand that will roll the transmission out from under the cab that is acceptable too.
charlieu's stand looks really nice and addresses having to support the clutch housing once it's out.
As for the 20 hours....as Owen and tractor vet pointed out...ain't gonna happen in that time. Usually a bunch of other stuff needs done while you're there.
One thing we used to find in 1486s was the range countershaft bearings loose.
If there is slop there, the range counter shaft bearings can be replaced and adjusted while split for a TA job.
Question for other techs...what do you do when the owner sends a tractor to you and the cab is full of clutter and/or there's all sorts of extra monitor or control harnesses run in a fashion that makes it extremely dificult to do the work?
This post was edited by Jim Naden at 15:14:07 08/17/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
