Farmall H Generator Bracket
Posted by SadFarmall on August 18, 2012 at 03:54:19 from (112.213.185.24):
I have now got nearly all the parts to fit a Delco-Remy generator and regulator to my 1940 Farmall H, but I have run into a problem. The bracket (50384 D) does not fit. The bolt holes in the cylinder head are nearly an inch further apart than the holes in the bracket. Was there more than one bracket for Farmall H tractors? Was there a different bracket for kerosene tractors? Thanks in advance,
SadFarmall
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
