Re: wd9-650d distributor mount/drive
Posted by D Slater on August 18, 2012 at 05:07:24 from (184.15.20.202):
In Reply to: Re: wd9-650d distributor mount/drive posted by jth88 on August 17, 2012 at 19:49:56:
I was trying to say its the same drive gear on the D350 pump that works on the drive housing and shaft of some other models. If you don't find the D350 housing and gear you can remove the pump gear and install it on the drive housing shaft from one of the other engines mentioned. More of those engines are around for parts than a D350.
Also most housings have a number on them. You need a number 261206R1 housing and shaft.
This post was edited by D Slater at 09:06:16 08/18/12.
