Re: 1466 hyd issue MCV?
Posted by Janicholson on August 18, 2012 at 06:26:47 from (96.24.99.126):
In Reply to: 1466 hyd issue MCV? posted by jimmyD1066 on August 17, 2012 at 22:53:21:
Might be an easy solution. Overfill the system by 5 gallons. There may be a Oring or suction line air leak that is near the level of the fluid. Operating at higher RPM allows the level to get just low enough to suck air. If it works, it is a good deal. If it were to include the remaining Hydraulic circuits (hitch) I would look to spline wear at the clutch. Jim
