Re: 806 stuck
Posted by rustcollector on August 18, 2012 at 11:06:17 from (166.249.197.127):
In Reply to: 806 stuck posted by Kly on August 18, 2012 at 07:54:57:
Take the valve cover off and be sure all valves will move freely, otherwise you may bend a push rod or damage the cam lifter. Follow the directions below to clear the water and WD 40 from the cylinders with air and turn back and forth with a pry bar in the teeth of the flywheel. The 806 does not have glow plugs.
