S C governor
Posted by Jimmy in TN. on August 18, 2012 at 12:45:39 from (71.88.3.210):
Hey guys don't give up on me but I am still working on this governor on this super c when I can,every thing checks out ok ,New thrust bearing,governor spring is good, weight and pins are good, bushing are good but I still don't get any thrust when I open throttle up ,it will rev up slowly and will not respond when in a pull, here is my question,the shaft that goes through the gov.the end next to the radiator according to the IH8 manuel,fig,390 says there is a thrust spring and a thrust pin lenth ways in the end of the shaft,I guess the pin holds the spring in, I can not tell, if there is, how does it come out? this tractor was running fine when I shut it down, the next time I started it up,problems,so what ever happend it happend all at once. everything else is checking out good Thank you for your help.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
