Posted by Janicholson on August 18, 2012 at 15:59:20 from (96.24.99.126):
In Reply to: Re: propper TA use posted by DeltaRed on August 18, 2012 at 12:50:29:
Delta is correct. Switch it in and out like a light switch. As fast as the lever will move is just fine. Use it all the time except coasting down hills (leave it in direct for that. The more you use it the longer it will last. I have one in a 350U that is original and it was used hard. Use it like an automatic trans from TA 5th to direct. Great tool. Adjustment is about every year with your use, but you will find it needs little adjustment. Moving the lever slow, is slipping the TA clutch. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
