Re: Farmall 350 Diesel Miss
Posted by Janicholson on August 18, 2012 at 16:07:16 from (96.24.99.126):
In Reply to: Farmall 350 Diesel Miss posted by Roger46 on August 18, 2012 at 15:57:56:
Crack each injector line when it is missing when it makes no difference, that is the problem cylinder. Swap injectors with the missing cylinder to see if the issue follows the injector. if not a compression check is next, but I believe it will be an injector issue. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
