Re: What's your least favorite repair/restore
Posted by Teakettle on August 18, 2012 at 16:22:17 from (76.19.137.65):
In Reply to: What's your least favorite repair/restore posted by Tom Fleming on August 18, 2012 at 13:50:16:
Reassembling the PTO clutch mechanism on a Cub. The factory
clearly recruited people with very small hands to assemble that.
(I can get my hand in the hole but then my fingers are
immobilized).
Reinstalling the ~200 lb front weight "slab bumper" on a
454/464 without any help is fun, too, as it adds the possibility of
serious injury to the mix.
But I think for sheer terror there's not much that can compare
with changing loaded tires and having to chase one when it
decides to go rolling down the road in the direction of various
damageable expensive things.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
