Re: IH little genius no.8
Posted by Leroy on August 19, 2012 at 05:50:27 from (69.88.205.38):
In Reply to: Re: IH little genius no.8 posted by Lmack on August 18, 2012 at 18:40:48:
That is probably not an option as even that straight roller bearing is not normally avaible anyplace anymore. I do have a place that can make enysize needed tho. The rear wheel is the same as on the rear of the steel wheel hay rakes and I think the hub would be same also but cannot check as no longer have any plows. But that cap is a screw on that is 2 1/4" thread and I think that is an option. I do have some of them.
