Re: cub, how much disc will it pull
Posted by john LaBoyteaux on August 19, 2012 at 07:35:47 from (76.14.94.14):
In Reply to: Re: cub, how much disc will it pull posted by tractor300 on August 19, 2012 at 07:06:32:
I have also used the standard 4' tandem with my cub. In those days it was assumed you would plow first then use the disk to refine the seedbed or keep down weeds. I found a single gang disk, either the front half of the tandem or especially the single gang liftable attachment worked much better but takes longer since you overlap each pass by half. The liftable unit also has larger disks.
Interesting information about a 185 head and aluminum pistons.
