Posted by Ih 784 on August 19, 2012 at 08:44:45 from (72.45.45.5):
I have an international 784 4x4 tractor with a zf front housing. I noticed about an inch of the axle shaft that goes into the differential on the right side was pushed out. Then I was using it and noticed the drive shaft that goes to the differential was slipping instead of spinning like it should. So I took the front axle out of the differential and 1/4 inch of the splines were wore down. So I put the shaft back in and pushed it all the way into the differential and when the wheel is turned and hits the stops it pushes the axle back out. Also I've noticed on some diagrams that on the right side there is a double universal joint and on my tractor I have a single. Also, the left side has a bigger universal joint than the right side that we're working on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
