Posted by Rod51M on August 19, 2012 at 13:16:44 from (71.254.123.101):
Thanks in advance to all who reply. I have gotten great help from you all over the past week or two. Also I have to apologize for the long-winded story that follows.
I replaced the water-header gasket on my M. Before I had removed the cover, I had taken all the hoses off but didn't realize I had to open the valve just under the water-header plate to compeltely remove all the coolant. So when I took off the plate, there was coolant just below the level of the plate. I am glad it was still there because of what happened next. I thoroughly cleaned the mating surfaces of the plate and the block. The plate was corroded, but I didnt' think the surface was too bad. I put the gasket on and carfully tighted the bolts in small increments, alternating from bolts that were opposite each other. I did not use a torque wrench becuase I didn't know the specs and also because I couldnt get at these with my torque wrench (they are behind the carb).
Next day I rolled the tractor out of my shop to begin painting it, so it got bumped around a bit and the coolant in the block sloshed around a bit too. I was really disappointed to see a small trickle of coolant running down the side of the block from my new gasket. I would hate to see it under pressure!
So I need advice. Should I have used gasket sealer? The gasket is a thin rubber one, not a cork (it is IH, not aftermarket). If I remove the cover now and the gasket looks ok, can I use the sealer and reuse the gasket?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
