Re: Lower Transmission Shaft Coupler Nut
Posted by dpoc on August 19, 2012 at 14:47:41 from (71.89.126.54):
In Reply to: Lower Transmission Shaft Coupler Nut posted by dpoc on August 12, 2012 at 14:32:19:
Thanks, to everyone for the information. I was finally able to get the coupler nut off of the lower transmission shaft. I was also able to remove the lower transmission shaft. When doing this I remove the rear bearing on the lower shaft and did not realize at the time that there was a
"ridge" or raised portion on one side of the bearing. Does anyone know to which side the "ridge" is suppose to go (front or back)?
