Posted by Janicholson on August 19, 2012 at 16:49:27 from (96.24.99.126):
In Reply to: #4 missing posted by Greg K on August 19, 2012 at 16:31:16:
Fouling a single plug can come from either a valve stem that is passing substantial oil into the intake, or rings that are letting it get on the top of the piston. Iven a good compression reading can blind a person to a stuck or broken oil control ring. If it were mine I would watch for blue smoke when pulling hard for 20 minutes, indicating rings, or blue smoke idling, or when coasting down hills, or at startup. Continuous blue is likely rings, intermittant is likely valve stem oiling. If in doubt put on a set of Umbrella seals, or Perfect Circle style valve seals to see if it corrects the fouling. No need to remove the head, Search the archives for -- rope to hold up valves. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
