Re: Starter works but Farmall M won't stay running
Posted by TomH in Pa on August 19, 2012 at 18:18:20 from (67.235.10.94):
In Reply to: Starter works but Farmall M won't stay running posted by Yelli523 on August 19, 2012 at 15:41:23:
Is there a wire running from the starter to the coil? Often they're wired like that to bypass an external resistor. If so that's what's giving you spark, until you release the starter. Then the normal circuit that goes through the resistor should take over, but it sounds like you have a bad resistor or connection so no voltage to the coil unless it comes straight from the starter.
