IH Farmall 560 Turbo Diesel Question
Posted by clay mcnamara on August 19, 2012 at 18:32:48 from (184.158.13.228):
Just bought a 560 diesel with the M&W turbo kit. Couple questions: This tractor seems to idle awfully high, when you add a turbo, does the idle need to be turned up for oiling purposes or cooling purposes?? Also, i know a lot depends on how much the pump got turned up but approximately what kind of horsepower can you expect out of a IH 282 with the turbo kit installed? 3. I have seen a few of these kits and they usually install a dry element filter externally, the 560 i got has the standard oil bath filter is this bad? 4. Also, is there a change in the viscosity of the engine oil? or shoudl a guy still use rotella 15w40. Thanks in advance!!!
