Posted by SadFarmall on August 20, 2012 at 02:02:54 from (121.79.12.159):
In Reply to: Timing 1946 Farmall H posted by Bob Borman on August 19, 2012 at 17:32:39:
If the tractor has magneto ignition and the timing is not too far out, you can just remove the distributor cap and gently turn the motor over until the impulse coupling trips. If the contact on the rotor is pointing to the place for Number 1 cylinder high tension lead, you are on the compression stroke for that cylinder. If not, turn the motor through another 360 degrees. For coil ignition, you can work out the compression stroke as Gene Bender has said. The method of putting your thumb over the plug hole requires extremely long arms or an assistant.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
