Don't think it matters, some bearings IH used there didn't have what you call a ridge. You probably have a # 255 bearing. Most counter shafts are undercut a little at the shoulder where the bearing is placed on the shaft. If not undercut just place the bearing ID with the most radius on the edge to the shoulder on the shaft. Bearing probably has a radius on both sides that slides on the shaft though. Front bearing locates the shaft in the housing so the rear bearing doesn't need to locate at a exact spot in the housing. If you want it back the same, sometimes you can look for discoloring on the bearing and tell the side to shoulder or retaining ring.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
