Re: Rust and a new engine question
Posted by BigTone on August 20, 2012 at 12:53:12 from (166.248.10.226):
In Reply to: Re: Rust and a new engine question posted by rustred on August 20, 2012 at 12:28:31:
thats a very good idea guys, I never thought of bringing them with the radiator! And I will no longer be using water in the cooling system (or at least not 3 gallons worth), the block was cracked because the previous owner went heavy on the water. My wifes uncle uses 100% antifreeze and has never had a cooling problem or a cracked block....
