Re: RPMs
Posted by mkirsch on August 20, 2012 at 14:09:48 from (64.80.110.74):
In Reply to: RPMs posted by dgerth on August 20, 2012 at 12:33:44:
It should be turning 1800 normally. You've got a problem.
Look at your throttle lever and make sure it isn't catching on the mounting bolts at the bottom. That limits the throttle lever travel.
There is a bolt that goes straight down into the top of the governor. That is the top RPM adjustment. Someone may have turned that in too far. Try loosening it.
