Re: C farmall head gasket
Posted by rustred on August 20, 2012 at 14:16:58 from (184.151.222.60):
In Reply to: C farmall head gasket posted by EJMn on August 20, 2012 at 12:32:24:
if you did not check head for warpage with a straight edge that is the most possible cause. it may need to be resurfaced. 60 lbs. seems light on the torque also.
