Re: 1086 no steering no Brakes
Posted by Janicholson on August 20, 2012 at 15:13:48 from (96.24.99.126):
In Reply to: 1086 no steering no Brakes posted by KY on August 20, 2012 at 12:03:17:
There is probably an air leak in the intake to the MCV pump. Over filling the system by 5 gallons will fix it until you take it apart for something else. If this works (commonly does) you are good to go. If it still doesn"t work, the MCV valve or other MCV components may be at fault. Jim
