Re: Powerwashing a Farmall 400
Posted by D Slater on August 20, 2012 at 19:26:08 from (184.15.20.202):
In Reply to: Powerwashing a Farmall 400 posted by Evan Iowa on August 20, 2012 at 06:32:47:
Clutch housing has two bolt holes on each side for mounting some things. They had plugs in the holes originaly. Lot of plugs are missing now. Those holes open into the T/A clutch compartment. High pressure spray that passes through the hole will result in a oily film of clutch dust getting on the T/A clutch parts. Also there's 2 drain holes for the compartment in the bottom. Try not to spray dirrectly up into those also. High pressure spray can damage the covering on older electric wires. New ones also if a high enough pressure. Generators, regulators, gauges and some other parts were originaly sealed for non pressure water. May want to take care with pressure.
