Re: Hydraulic Fluid
Posted by Fullers Farmalls on August 20, 2012 at 20:25:23 from (24.239.77.45):
In Reply to: Hydraulic Fluid posted by SMTA on August 20, 2012 at 09:11:08:
Original calls for straight 30. If you are changing implements between tractors run the hy tran as thats more common. As for the rear end I just went through this on my Super M. I found 85-140 as the cheapest at $53 for 5 gallon. It takes 13 gallons though so it gets pricey. Original was straight 90. If you are in a cold climate and use it in the winter a multi rear end oil will be slightly better
