Re: Farmall A trans. bolts
Posted by Hendrik on August 21, 2012 at 00:37:39 from (194.53.253.51):
In Reply to: Farmall A trans. bolts posted by bkpigs on August 20, 2012 at 19:13:45:
As you suggested, these holes are for mounting implements. Our late friend Hugh Mackay used them to mount an umbrella (see link).
Using one left hand plow and a right hand plow (single bottom) implies the use of a split rockshaft (between the fenders) to raise and lower the plows more or less independently. A set of over center linkages mounted to these holes. There are probably other uses.
HTH, Hendrik
