Re: 1086 no steering no Brakes
Posted by Owen Aaland on August 21, 2012 at 14:58:20 from (216.47.35.53):
In Reply to: 1086 no steering no Brakes posted by KY on August 20, 2012 at 12:03:17:
The PTO check is to verify that the shaft is turning. If the PTO still works the problem would most likely be oil related. No PTO and no hydraulics would indicate a mechanical problem with the drive, most likely the splines on the pressure plate hub and IPTO input gear. That usually makes noise at least for a little while. Having he rivets shear out of the hub will be silent. By removing the cover under the clutch you can see the hub and the front of the IPTO gear.
