Re: distillate head with a gas motor, HELP
Posted by Janicholson on August 21, 2012 at 17:34:21 from (96.24.99.126):
In Reply to: Re: distillate head with a gas motor, HELP posted by BigTone on August 21, 2012 at 08:48:32:
A rebuildable gas 450 or 400 head should cost more like 400 bucks. A cracked head that is cracked where compression will be lost will not be valuable unless fixed. Shop for a better fix. Stitching or welding. Jim
