Re: SMTA water in oil pan
Posted by rustred on August 21, 2012 at 20:22:38 from (184.151.222.60):
In Reply to: SMTA water in oil pan posted by Paul A Young on August 21, 2012 at 20:08:10:
remove oil pan and put a cardboard under it and you should be able to see yourself where its leaking. may have a crack around or in cyl. bore even between sleeve and bore. or could be crack in head. have rad full with water too. you could even remodel a rad cap for and air chuck and give it about 5lbs. of air, but you should have a regulator for this not to blow up the rad or hoses.
