Posted by sflem849 on August 22, 2012 at 05:30:21 from (69.197.84.39):
In Reply to: Fuel in crankcase oil posted by Janicholson on August 21, 2012 at 18:16:24:
Janicholson said: (quoted from post at 18:16:24 08/21/12) The injection pump seeal at the drive is worn. Depending on model and pump it is either real easy, or pretty easy. Make sure the engine is at TDC #1 before removal, do not turn the engine and keep the gear teeth in time. Jim
That is not a 100% of the time solution. However, if you are getting case dilution in your injection pump that is then going to your crankcase it is.
My MD problems were caused by leaking/malfunctioning injectors. Rebuilt the injectors and no more problems.
Nobody asked what tractor this was. I assume it is a gas start diesel?
This post was edited by sflem849 at 05:31:43 08/22/12.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
